Having drift in video with playback with Aja Kona Lhe card in FCP7
James Vincent
on Mar 28, 2013 at 10:02:44 pm
Ok here is the dealio. MacPro's with Aja Kona Lhe cards running FCP 7. Aja Cards are up to date to 9.1 software.
So whatever settings in the aja control panel are obviously overidded when fcp opens it uses all the presets in fcp7. I have tried many things to get the video to playback at the same speed as the computer but it drifts. Here are the specs
Footage =
Apple ProRes Proxy 1920x1080p 23.98
Sequence =
Now our ,monitors are s***. They are old sony crt monitors and being run from the kona lhe cards via rgb.
Now getting drift the more it plays the more it drifts. Now I am not referring to laying back to tape. Just editing. just editing. What are the correct settings for editing to see the footage at full speed on the sony crt monitors. It has to be a setting cause the other bays using the same sony crt monitors but with black magic cards work just fine. I always thought aja was better but this shoudn't be so difficult.
What settings are the correct settings?
-james
____________
40tb Xsan
