Better FCP 7 SmoothCam plug in
Enrico Lappano
on Mar 26, 2013 at 3:02:12 pm
Can someone recommend a better smoothcam plug-in solution than the one that is included with FCP 7? Unless I'm not using it properly, (primarily with 7D clips and sometimes HDV), it leaves noticeable "jello" jitter and cropping. I was told that Premier has a good plug in for this, as well as FCP X.
I'd really appreciate any feedback.
Dave LaRonde
Re: Better FCP 7 SmoothCam plug in
on Mar 26, 2013 at 3:53:26 pm
Yup: both Premiere Pro and After Effects have the Warp Stabilizer, with a Rolling Shutter feature. Very handy.
If you plan to use Warp Stabilizer in either application, I STRONGLY recommend transcoding DSLR footage to ProRes 422 or HQ before using it. The Warp Stabilizer feature looks backward & forward in time, and H.264 really slows the process down.
Dave LaRonde
Former Sr. Promotion Producer
Enrico Lappano
on Mar 26, 2013 at 4:12:40 pm
Thanks Dave. Can I use that, or is there a plug-in available that's as effective as the "Warp Stabilizer, with a Rolling Shutter feature" available for FCP 7, which I am editing on? My footage has been transcoded to ProRes 422.
Steve Eisen
on Mar 26, 2013 at 5:55:45 pm
Lock and Load from CoreMelt
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Anna Ingenthron
on Mar 26, 2013 at 9:37:13 pm
Importing the shot into Apple Motion (in the FCP suite) as a project and adding the behavior "Stabilize" under Motion Tracking. Smooths things out nicely if you don't mind the little export and import.
Enrico Lappano
on Mar 26, 2013 at 10:16:01 pm
Between the three options for FCP 7 for best smoothcam is it safe to say first that the FCP 7 smoothcam plug-in is not even an option (at least from my experience, but I haven't compared it with anything) ?
But between the other two, ultimately, I'm after the "smoothest" option. Will $100 for Lock and Load X bring best results or extra time importing into Apple Motion?
I appreciate all your feedback, cause the effect can make a dramatic difference.
