Editing directly MOV files with IMX50 codec in FCP7 ?
Carlos Soares
on Mar 24, 2013 at 10:35:34 pm
I am starting a project in FCP 7.0.3 and I received some files to test and define the workflow.
The codec used is the IMX50.
As for the container I received MXF files and MOV files (plus the XML files associated)
As I can edit the MOV files directly is there any reason why I shouldn't? Any loss of quality?
The final output will be PAL (wide) and it will be exported to tape.
Jeremy Garchow
Re: Editing directly MOV files with IMX50 codec in FCP7 ?
on Mar 25, 2013 at 1:54:52 am
There's no difference in quality between MXF and mov imx50.
You'll be just fine using the QuickTime movies.
Jeremy
Carlos Soares
on Mar 25, 2013 at 10:08:05 am
That-s really great news, Thanks!
Cheers,
carlos
