Converting A FCP Project for DVD
Romina Rey
on Mar 24, 2013 at 8:29:54 pm
Hi
I just had a quick question and taking any suggestions.
I was just given a FCP project to export and compress for DVD purposes. However, the project was cut by someone else in h264. I was thinking of converting the footage to Pro Res and replacing the h264 for a better work flow and possibly final image quality for the DVD.
Thoughts?
Much Appreciated.
Romina
Shane Ross
Re: Converting A FCP Project for DVD
on Mar 24, 2013 at 9:03:01 pm
Change the sequence Compressor to ProRes and render. Try that.
(Sequence Settings: Compressor)
Shane
Little Frog Post
Romina Rey
on Mar 24, 2013 at 9:21:31 pm
Thanks for your suggestion. I'll try that.
Do you think that's better than recompressing the sequence using media manager?
Shane Ross
on Mar 24, 2013 at 11:04:32 pm
This is quicker and often works. If it doesn't, decompress with MM
Shane
Little Frog Post
