XDCAM HD422 files to Pro Res embedded timecode drift
Jean Davis
on Mar 21, 2013 at 7:03:49 pm
Hello There -
I'm hoping someone might be able to steer me in the right direction here.
I received my files and they are in the XDCAM HD422 1080p24 codec. My mixer wants them in Pro Res.
I"ve tried exporting these files to Prores 422 a number of times and I keep getting the same timecode drift when comparing the two files in QT7 and comparing my TC burn in on the pro res file. The two pops and first frame of picture are spot on but shortly into the reel my XDCAM file will hang on a frame longer on the shot than the Pro Res version and by the end of the reel it's about a second difference. The clips are the same length though and when I bring them into final cut all matches up and looks well.
Any Ideas on the issue?
thanks in advance.
Jeff Meyer
Re: XDCAM HD422 files to Pro Res embedded timecode drift
on Mar 22, 2013 at 2:20:53 am
This sounds like a task for the Media Manager to me. You converting externally?
