OMF Sync issues
Louis Basslines
OMF Sync issues
on Mar 18, 2013 at 1:19:28 pm
I have some footage on a timeline which is 29.97 however I do have few cuts on the timeline which are 25FPS. My session is at 29.97. All audio is synced on timeline and sounds good. I have exported an OMF. When I open in protools the audio is in sync with the reference mp4 video export. When I import my protools mix bounce back into FCP it is drifting out of time. I believe the omf protools project should be the same setting as my FCP setting however the protools session must have a setting out for my bounce to be a different length. Any hints appreciated.
Macbook Pro 2.8Ghz Intel core duo 4GB ram OS10.6.6
FCP 7
Nick Meyers
Re: OMF Sync issues
on Mar 18, 2013 at 2:39:45 pm
this seems to come up a lot,
check your sequence pre-set in FCP a/v settings.
it needs to be the same frame rate as your working sequence and PT bounce.
if it isn't, you can get drift on imported audio.
nick
Louis Basslines
Re: OMF Sync issues
on Mar 19, 2013 at 1:52:26 am
Nick, thanks for you helpful reply. Yes that was precisely the problem. All syncing well now thank you.
FCP 7
