Exporting DV PAL 16x9 at highest quality and deinterlace
Tomas Valenzuela
on Mar 16, 2013 at 7:21:23 pm
I would appreciate if someone could advice on steps and settings for exporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage. The documentary is intended initially for film festivals and hopefully broadcast and DVD.
The footage has been shot on DV PAL Anamorphic (hence final dimensions should be 1024x765).
I have read FCP's guide, forums and many articles online.
What I finally understand is that I should export as follows:
File > Export > Using Quicktime conversion
Video settings > Compression Type: DV-PAL > Frame rate: Current or 25 > Compressor quality: Best > Scan Mode: Interlaced (Since FCP does not a good job on this) > Aspect ratio: 16x9 (here?)
Video Size > Pal 720x576 16:9 (here too?) > Preserve aspect ratio: NO (no need?) > De-interlace: (Since FCP does not a good job on this)
This works, when I open the file in quicktime with property inspector all details are OK. But the image doesn't show side to side horizontally (on the left and right there is a 2 black pixels width vertical gap). Also, and I know i'll be told off, when I export the same way but with Compression to NONE, looks like heaven, but I know the file size is impossibly BIG to work on, is this the only reason for not using NONE.
On the subject of De-interlacing, I have found on the internet the answer might be:
BorisFX or RevisionFX best for FCP
McBob (a script not for FCP no?) that uses motion compensation
Is there a plugin for FCP that uses motion compensation?
I will leave it up till here, many thanks for your time,
Tomas
Computer specs:
Model Name: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 2 GB
Bus Speed: 1.6 GHz
Boot ROM Version: MP31.006C.B05
SMC Version (system): 1.25f4
Chipset Model: ATI Radeon HD 2600
Type: Display
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 256 MB
Vendor: ATI (0x1002)
Device ID: 0x9588
Revision ID: 0x0000
ROM Revision: 113-B1480A-252
EFI Driver Version: 01.00.252
Displays:
Cinema:
Resolution: 1680 x 1050
Depth: 32-Bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
Display Connector:
Status: No Display Connected
Rafael Amador
Re: Exporting DV PAL 16x9 at highest quality and deinterlace
on Mar 18, 2013 at 11:05:46 am
[Tomas Valenzuela] "exporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage."
You don't need to de-interlace for Color Correction.
[Tomas Valenzuela] "xporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage. The documentary is intended initially for film festivals and hopefully broadcast and DVD.
The footage has been shot on DV PAL Anamorphic (hence final dimensions should be 1024x765)."
If you are going Broadcast and DVD, keep standard PAL 720x576.
1024x576 Squared Pixels is for web download.
Forget about "QT Conversion".
If you have edited the PAL DV stuff on a PAL DV sequence, export a QT movie with the current settings:
Export > Quick Time Movie..
rafael
Tomas Valenzuela
on Mar 22, 2013 at 12:07:34 am
Hi Rafael,
Thanks for your reply.
I am exporting for color mix, so what you suggest is to export as 4:3 interlaced from Export > QTM? Not 16:9?
Whichever way, when I export through QTM as anamorphic or as current settings (like my sequence in FCP) the result in Quicktime property inspector shows the ACTUAL export as 1049x576, and when I try 4:3 the result shows 789x576.
I appreciate any further comments, many thanks, Tomas.
