Unable to Initialize Deck
Angela Zumbrum
on Mar 14, 2013 at 7:40:22 pm
Searched and read almost every post with this same Subject before posting. Having NO luck.
Using Mac OSX 10.5
FCP 6
Capturing min DV from a Sony Camera ( DCR-HC42 NTSC)
Connected with FireWire from camera to Computer
Unable to initialize deck, you still may log offline. is this only message I am getting.
Any help would be appreciated!
Steve Eisen
Re: Unable to Initialize Deck
on Mar 14, 2013 at 8:15:32 pm
Try using Easy Setup.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Angela Zumbrum
on Mar 14, 2013 at 8:48:56 pm
Did that too. I typically edit HD video, and was a little taken back while trying to change all of the settings manually. What option should I chose for Easy Setup ? I've tried NTCS. What options should I chose? Rate? Custom Setup? Thank you.
Steve Eisen
on Mar 15, 2013 at 3:06:08 am
DV NTSC is all you need. FCP does the rest.
Steve Eisen
Vice President
Angela Zumbrum
on Mar 15, 2013 at 1:30:51 pm
Still nothing. I know that I have captured using this camera before. What the heck am I forgetting this time? Tried 2 different Firewire cables, two different ports on the Mac. I am capturing to an external hard drive, and thought that it may be causing the issue. So, just to test, I tried capturing to my internal system drive and got the same message. Unable to initialize deck. UGH!!!
