Strange Bedfellows: Final Cut 6, Mountain Lion, Canon 5d Mark ii
Jana Birchum
on Mar 12, 2013 at 6:49:49 pm
Hi folks,
I just upgraded to Mountain Lion, and cannot import my 5d footage into Final Cut 6. It worked before the upgrade.
I've re-downloaded the plug-in, restarted the software, then the computer. I get the "directory structure" error.
I can use Streamclip, but I was wondering if there's a fix so that I can continue to use Final Cut.
Any suggestions, other than switching to Premiere?
Jana B.
Shane Ross
Re: Strange Bedfellows: Final Cut 6, Mountain Lion, Canon 5d Mark ii
on Mar 12, 2013 at 9:20:04 pm
Yeah...don't use Mountain Lion. Mountain Lion is hiding part of that structure that FCP 6 needs to see. Mountain Lion is the culprit.
If you want to continue using an old...and I mean 5.5 years old...editing software, you need to stick to the older OS that supports it. Need to use Lion or Snow Leopard. 10.4 or 10.3. Unfortunately, that means you need to back up your system, and reformat and reinstall from scratch.
Shane
Little Frog Post
Brent Dunn
on Mar 13, 2013 at 2:11:49 pm
That's the reason I haven't updated my system in a few years. If it works, don't fix it.
I'm about due for a new machine. That's when I switch to Premier.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.net
Sony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro
with Final Cut Studio Adobe CS6 Production
Jana Birchum
on Mar 13, 2013 at 2:15:06 pm
Thanks for the info. I use Final Cut 7 at work, and haven't wanted to invest in an upgrade for the little I do at home. Esp. since we're NOT moving to Final Cut X.
I'm good with Mountain Lion, and we're in the process of switching over to Premiere at work, so I think that's the way I'll go. No use throwing away money on old software.
Thanks guys!
Jana B.
Christopher McDonell
on Mar 16, 2013 at 8:32:50 pm
Hmm. I don't know about importing Canon 5D footage (you need a special plugin for that?), but I've been running FCP 6.0.6 on ML 10.8.2 with no problems whatsoever. I'm now curious to know if 10.8.3 will be the same.
