P2 footage to play on non FCP computer
Keith Jorgensen
on Mar 11, 2013 at 4:41:15 am
How do I get P2 and/or DVCPro 24p 720p (960x720) footage from Final Cut Pro to play on a computer without FCP at the highest quality and in the proper aspect ratio (1280x720)? I have FCP, compressor, & MPEG Streamclip to convert the footage. It currently will only play audio or it errors. Thanks!
Shane Ross
Re: P2 footage to play on non FCP computer
on Mar 11, 2013 at 4:53:45 am
Convert the footage to ProRes 422, 1280x1080. Use Compressor or MPEG STREAMCLIP to do this.
Shane
Little Frog Post
Michael Gissing
on Mar 11, 2013 at 6:05:24 am
ProRes422 will work on a PC with quicktime 7 installed. If this is a final master that you just want to play on most computers then converting the finished master to H264 (1280 x 720) will mean it should play on most computers, even if quicktime isn't installed.
H264 is a pretty universal codec for most computers these days.
