make slow mo with footage look like regular speed
Stephen Franciosa
on Mar 10, 2013 at 2:00:48 pm
In FCP7 whats the correct speed change to speed up footage shot in slow motion. I have some ARRI Alexa footage which was shot at 48 fps and 72fps which I need to play at regular speed. My sequence is 23.98. All my attempts end with a weird stutter. I don't really like the frame blending effect.
Rafael Amador
Re: make slow mo with footage look like regular speed
on Mar 10, 2013 at 3:58:07 pm
have the footage being conformed to another time-base?
rafael
Conner Lambden
on Mar 10, 2013 at 6:00:35 pm
Have you tried 200.167% for the 48fps and 300.25% for the 72fps? I don't think you should need to use any frame blending for this.
Conner Productions - Hollywood Caliber Effects at Your Fingertips
http://connerpro.com/
Stephen Franciosa
on Mar 10, 2013 at 11:16:04 pm
the footage was never transcoded and plays native at 23.98. i think the alexa doesn't need to be transcoded and records native at Prores and other compatible formats. its 444.
so far it looks like 250% works well, but im going to try those percentages as well.
Nick Meyers
on Mar 10, 2013 at 11:32:14 pm
200% for the 48fps
300% for the 72fps
this will give a playback speed of 24fps. close enough to 23.976.
when you make the speed changes, turn off frame blending.
i wouldn't be too surprised if some of your stuttering is due to playing Prores4444 clips with effects.
nick
Stephen Franciosa
on Mar 11, 2013 at 3:04:02 pm
thanks. what about canon footage which was shot slow mo (59.94) then converted to 23.98?
Bret Williams
on Mar 11, 2013 at 5:45:36 pm
Math. 59.94/23.98=2.49958
250%
Stephen Franciosa
on Mar 11, 2013 at 7:33:12 pm
yeah would have never thought to divide that but worked perfectly.
