The Waveform Cache Files Folder does not have read/write access
Andy Duggan
on Mar 7, 2013 at 6:33:00 pm
Hello
I have read several posts and forums regarding the issue I'm having but I haven't been able to reslove it yet and I'm getting pretty desperate. Any advice gratefully received.
When I go to launch FCP the full message I get is:
Please select a new folder in the System Settings Dialog or correct the problem on disk.
Then FCP quits before I can go in to the system settings and attempt to resolve this.
I am on MAcBook Pro OS X 10.6.8 2.66 GHz Intel Core 2 Duo
The version of FCP is 6
It has worked without fault for me for years.
So far I have been through Disk Utility and reset permissions and verified disks and repaired them.
I have deleted the contents of the Waveform Cache Files Folder and tried deleting the folder itself.
I have rebooted. tried a PRAM and and SCM restart as per other users with this problem.
Can anybody offer any suggestions??? Many Thanks.
Massimo Alberto Croce
Re: The Waveform Cache Files Folder does not have read/write access
on Mar 8, 2013 at 8:13:43 am
Try deleting final cut preferences locate in your home/library/preferences.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Chris Batte
on May 6, 2013 at 9:04:44 am
Did you find a solution? I'm having the same problem but with 10.8.3
