Creating text effect in fcp
Ewan Maccormick
on Mar 6, 2013 at 8:49:17 pm
Hi there,
I have been trying to find out how to create this effect in FCP or in motion, but I cant even seem to articulate it enough to search for it.
Basically, if you watch this at 5 seconds in the text effect I am looking for begins.
Basically it is pinning the text to move with something in the shot.
I have tried it with keyframes in fcp but it looks jerky and awful and I wondered if there was a simpler way to do this in motion or in fcp.
any help would be very much appreciated.
Cheers
Shane Ross
Re: Creating text effect in fcp
on Mar 6, 2013 at 9:17:39 pm
It's called TEXT TRACKING, and is something you'd do in After Effects.
Shane
Little Frog Post
Mark Suszko
on Mar 6, 2013 at 10:11:43 pm
Yes, you can do this in Motion by first applying a tracker to the footage, then any graphic you put in Apple Motion lock to the motion. Same as AE can do, but it may be a little simpler in Motion.
Look for Stephen Smith's tutorials on the COW tutorials page because I believe he shows how to do this there. Or ask Stephen straight-up in the Motion forum, where he's like the G%D#$ Bat Man in terms of fast help when you need it. Great guy, good teacher.
Ewan Maccormick
on Mar 7, 2013 at 9:30:51 pm
Thanks so much guys. A really great help. I will head over to the Motion tutorials now and have a look for stephens stuff.
Cheers again for taking the time to respond.
Ewan
Stephen Smith
on Apr 19, 2013 at 6:10:15 pm
Mark,
Thanks for the kind words.
Yes, this is easy to do in Motion 4. I would recommend that you check out this tutorial: http://www.digitaljuice.com/djtv/detail.aspx?sid=470&sortby=&page=1&rpid=0&...
This is how it was done:
-Text layer was added above the layer with the movie.
-Match Move behavior added to text layer
-Hit F2 to open Behaviors tab
-Make sure Type = Transformation
-Move the anchor point to the area you want to track
-Select the Scale Adjust button so Position and Scale are enabled
-You will get a new option below Anchor called “Rotation-Scale.”
-Click on the Analyze button and best of luck.
Stephen Smith - Follow me on Behance
Utah Video Productions
Check out my Vimeo page
