popping & distortion with my audio in Final cut but not in Quick Time...
christina rule
on Mar 4, 2013 at 9:02:50 pm
When I'm exporting and playing back (inside FCP) my video out of Final Cut I'm noticing some popping and distortion with my audio. Now, when I playback the audio in quick time I'm not noticing any extra noise. I checked my sequence settings in quicktime and all seem to match up with the audio file settings. I can't seem to figure it out...anyone have any ideas?
Thanks in advance for your time and help!
Here is a link to my screenshot: 5579_screenshot20130304at3.56.56pm.jpg.zip
http://www.christinarule.com
jerry wise
Re: popping & distortion with my audio in Final cut but not in Quick Time...
on Mar 4, 2013 at 9:31:17 pm
try converting your mp3 to aif or wave. that might be the issue
christina rule
on Mar 4, 2013 at 11:53:06 pm
Thank you! That did the trick in regards to playback inside of FCP. However I'm still noticing when I export it the audio is really fuzzy... any ideas?
christina rule
on Mar 5, 2013 at 12:12:49 am
Never-mind, I realized I wasn't exporting at the correct sample size. Once I changed this all sounded fine on the final export. Thank you all for all of your time and suggestions!
