Transparent Illustrator file for FCP
david mayer
on Feb 28, 2013 at 8:53:10 pm
The client uses Illustrator. What instructions do I give him
to send me the logo with a transparent background?
iMac 2.8 GHz Intel Core i7, 8 GB
OS 10.6.8
Final Cut Pro 7.0
Mark Suszko
Re: Transparent Illustrator file for FCP
on Feb 28, 2013 at 9:10:41 pm
Save as 32-bit with alpha channel. and all layers saved .psd, .tga. .tif or .png will work as file extensions.
david mayer
on Feb 28, 2013 at 9:29:00 pm
awesome - thanks
OS 10.6.8
Final Cut Pro 7.0
Dave LaRonde
on Mar 1, 2013 at 7:57:41 pm
Don't forget that Illustrator documents are primarily vector in nature. If you convert them to bitmap images for FCP, they won't be vector any more.
The primary virtue of a vector image is that it can be scaled up and maintain sharp edges. You'll lose that ability.
Dave LaRonde
Former Sr. Promotion Producer
david mayer
on Mar 2, 2013 at 11:13:41 pm
Thanks, Dave. Did not know that about vectors.
I had the client save as png and select transparent
background. Looks OK and edges are OK. Is there
a way to save with even better edges and transparent
background?
OS 10.6.8
Final Cut Pro 7.0
Mark Suszko
on Mar 3, 2013 at 1:21:19 am
I prefer targa or tif for this, but .PSD will also work.
Dave LaRonde
on Mar 4, 2013 at 5:51:19 pm
If the graphics will remain static -- or at least not scaled beyond 100% -- PNG's with an alpha channel are fine.
Dave LaRonde
