Mixed Frame Sizes sequence
Maria Meredith
on Feb 28, 2013 at 7:37:56 pm
Hi
I've been given footage shot with two different camera's, though I will be editing them into one sequence.
I realise I can render in FCP so that either will play in the others sequence set up, but wondered if there is a quicker way to convert, and if so which way (1440 footage to 1024 or vice versa)?
The files are:
HDV / 1440x1080 50i / 25fps (originally MTS files converting using ClipWrap)
and
H264 / 1024x576 / 25fps
Thanks as always,
M
Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
FCP Studio 7.0.2
Mark Suszko
Re: Mixed Frame Sizes sequence
on Feb 28, 2013 at 8:33:07 pm
Well, FCP 7 can edit the HDV all right natively, but it cannot do that for H.264, so for speed's sake, I would convert the h.264 to match your other HDV camera, or make a sequence in pro res and convert both cameras to that.
Maria Meredith
on Feb 28, 2013 at 8:41:04 pm
Ah, excellent. Thank you very much for your reply, just wanted to be sure which way to go with it all.
M
FCP Studio 7.0.2
