FCP Export
Goutom Ain
FCP Export
on Feb 25, 2013 at 8:02:03 am
Is there any way to export a video from fcp with TCIN=0 without moving the clip to the start of timeline. I need all video to get TCIN=0 to play the files in our automation.
Shane Ross
Re: FCP Export
on Feb 25, 2013 at 10:50:24 am
What is "TCIN=0?"
Timecode IN to start at 00:00:00:00?
Shane
Little Frog Post
Goutom Ain
Re: FCP Export
on Feb 25, 2013 at 1:28:17 pm
Yes Timecode IN=0 i.e. every file need to get this timecode while exporting from FCP.
Shane Ross
Re: FCP Export
on Feb 25, 2013 at 2:24:24 pm
The only way to get that is to have a sequence with the timecode you want.
Shane
Little Frog Post
Nick Meyers
Re: FCP Export
on Feb 26, 2013 at 7:18:57 pm
if you export the clips using quicktime conversion, the TC track will start at zero,
but you'd be transcoding, or re-compressing
quicker (by a matter of minutes, possibly seconds) than setting a bunch of sequences to TC0 would be to batch export your clips,
then bringing them back into FCP and changing the TC to zero.
nick
