Trying to import MP4 with Linear PCM codec into FCP7
Molly Sharp
on Feb 24, 2013 at 12:01:11 am
I've tried downloading the Sony Log and Transfer plug in, but I cannot figure out if that helps once the file is already in the MP4 state. The MP4 was provided by a client, so there is no way to get the native file.
Thank you.
Brian Stokes
Re: Trying to import MP4 with Linear PCM codec into FCP7
on Feb 24, 2013 at 12:33:00 am
Use free applications like MPEG Streamclip or 5DtoRGB to convert it to a file you like for example Apple ProRes, etc.
Then bring it into FCP.
iStoker.net
Rafael Amador
on Feb 24, 2013 at 2:35:07 am
[Molly Sharp] "I've tried downloading the Sony Log and Transfer plug in, but I cannot figure out if that helps once the file is already in the MP4 state. The MP4 was provided by a client, so there is no way to get the native file."
Are you talking about MP4 coming from XDCAM cameras?
You can't use L&T without the full card structure.
If you have just the MP4 you need to rebuild the file/folders structure using the SONY Clip Browser. Then you can run L&T/
The other solution is to use Calibrated plugin:
http://www.calibratedsoftware.com/MP4EXImport_Mac.asp
rafael
