problems viewing Full HD
Gabriel Angel
on Feb 22, 2013 at 2:42:08 pm
I am having problems viewing Full HD on my Macbook pro 2.4Ghz 4GB ram, 17 inch (1920 x 1200 ) and have installed OSX Snow Leopard 10.6.8.
I use a hacked Gh1, and the story of how the problems occurred is as follows:
6 months ago everything worked fine, I was able to view the AVCHD (.mts files) with VLC player, and the conversion in FINAL CUT PRO 7 to Proress LT worked fine, and I was also able to see the exported Proress in QT player smoothly.
A day my the charger for the laptop stopped working, probably because of an unequal flow of electricity, and simultaneously the battery died.
After that event I have not been able to view Full HD anymore…
The .MTS files opened but remained blocked after 2 seconds, and only the sound was heard.
The Proress LT files could be seen in QT player but not smoothly. Very annoying.
I bought another charger so that I could use the laptop again, and now a big detective work started:
1. I made a Apple hardware test on the computer to cheek if it could be the NVIDIA GeForce 8600M GT that caused the problem, but according the test everything was working well.
2. I made a ram test, all in order
3. I tested the harddisk at western digital service center, and it is working fine
4. I reinstalled Snow Leopard with the same settings and programs as before the accident, and no change, still problems. I tried Lion and still the same.
5. I went to a mac repair shop that booted from an external harddisk and still the same problem with the files as on the osx installed on my own computer.
5. I made a trash preferences with preference manager and no change
6. And I will mention that I have tried with many different files, so it is not one corrupt file that is the problem.
7. I also experience problems in viewing the files that I have compressed via MPEG Streamclip or in Cmpressor, they often also docent run smoothly, problems that did not occur before.
Any suggestions?
William Carr
Re: problems viewing Full HD
on Feb 25, 2013 at 7:54:49 pm
Are you playing back the media from an external? Via USB or Firewire?
FWIW after new OS installs I have sometimes had problems playing back various compressed codecs that played fine before. But it's odd that ProRes would be problematic unless your media is on your system drive.
Gabriel Angel
on Feb 26, 2013 at 1:08:09 pm
my media is on my system drive, I will test in on an external drive with FW 800, but it worked fine like this previously.
Gabriel Angel
on Feb 26, 2013 at 1:20:56 pm
I tested on an external drive and the problem is the same, and yes it is ProRess
William Carr
on Feb 26, 2013 at 10:16:48 pm
So is the only aspect different than when everything worked great, that the internal battery is dead and you are using a new AC adapter? Is the AC adapter an Apple model, new?
Gabriel Angel
on Feb 27, 2013 at 7:12:32 pm
Yes I use an original apple MabSafe charger.
Today I tested the laptop with a battery that is functional, and it seems that that was the issue, it played the Full HD video much better like that, it seems that it needs both energy from a charger and the battery simultaneously in order to play HD video
William Carr
on Feb 27, 2013 at 9:37:36 pm
It feels so satisfying to have a problem resolved!
Gabriel Angel
on Feb 28, 2013 at 11:38:51 am
thats true :-)
good to remember...I was still a little disappointing that it didnt work without battery, but indeed its a good feeling
