FCP7: How to edit only audio without unlinking?
Sum Choi
on Feb 22, 2013 at 9:36:42 am
Sometimes I just want to edit the audio and not the video when I'm making tweaks. Is there a fast way to only select the audio without unlinking using Shift-L? I am not sure if you guys are familiar with Premiere but in Premiere you can select only the audio or the video by holding OPT. Is there a similar function in FCP7?
Rafael Amador
Re: FCP7: How to edit only audio without unlinking?
on Feb 22, 2013 at 12:01:55 pm
You can lock the video track.
The small lock icon at the left.
rafael
Joe Barta IV
on Feb 22, 2013 at 2:31:51 pm
Hold down "Option/ALT" when trimming on the timeline. This will allow you to move the video or audio in/out points independently without unlinking them.
Bars & Tone
SALUTE!
Bret Williams
on Feb 22, 2013 at 8:43:25 pm
Unless you have linked selection turned off in which case it's exactly the opposite.
Dave LaRonde
on Feb 22, 2013 at 10:33:45 pm
I hope this isn't lip-sync audio. If it is, it's time for Plan B....
Dave LaRonde
Former Sr. Promotion Producer
Nick Meyers
on Feb 23, 2013 at 1:06:04 am
" in Premiere you can select only the audio or the video by holding OPT. Is there a similar function in FCP7?"
yes.
weird you didn't just try it!
ALSO
Shift L will turn off timeline linking.
the result of this is that video & audio behave as if independent,
and in this mode, when you hold OPTION they behave as if linked, a reverse of the default situation.
nick
