Exported Audio is shorter duration when brought back into FCP
Mark Mathews
on Feb 20, 2013 at 9:08:31 am
Hi there, I am really at a loss and desperate for some help.
I have done this once before and it worked fine, but for some reason something is not working. I am setting up six tracks of audio, 2 stereo panned left and right, 2 music and effects left and right and 2 dialogue. When I did this before I mixed the sound as I wanted in FCP and then exported the tracks as I needed them, as AIFF's.
I then brought the AIFF's back into FCP, lined them up with the footage and all was good.
However, I have gone to do the same again and when I bring the audio back in the audio track is less in duration?
So, on my timeline the in and out points tell me the clip is 22minutes.
I export it as an AIFF and QT tells me the clip is 22minutes
When I bring it into FCP it tells me it is 21:58:15 and no longer matches my footage?
What is going on?!! All the footage has 48khz audio. I export it as 48Khz and I have checked the in and out points a million times.
I have so much to do and yet can't get any further with this issue. Please, can someone help?!
Nick Meyers
Re: Exported Audio is shorter duration when brought back into FCP
on Feb 20, 2013 at 8:07:23 pm
double check your sequence pre-set
if the frame rate does not match your working sequence, you can have sync issues importing audio.
nick
Mark Mathews
on Feb 20, 2013 at 8:11:34 pm
Hey Nick,
Yep, my sequences are 25fps and my footage is the same...?
Nick Meyers
on Feb 20, 2013 at 8:24:16 pm
in your A/V settings, do you have a 25fps sequence checked as the pre-set?
nick
Mark Mathews
on Feb 20, 2013 at 8:42:44 pm
In the Audio/Video settings I have HDV 1080i50 preset, which is 25fps...
Nick Meyers
on Feb 20, 2013 at 9:41:11 pm
sorry, then i am at a bit of a loss, too.
a clarification:
are you exports cut short, or are they playing out of sync?
if cut short, try adding some slug to the end of the track and re-export.
do you need AIFFs?
can you export as quicktime movie, current settings. audio only?
have you tried copying your timeline into a new sequence and trying the export from there?
nick
Dave LaRonde
on Feb 21, 2013 at 3:42:41 pm
Audio render files can be flakey sometimes. Go to the Render Manager, find the project's audio render files, delete them and try again.
Dave LaRonde
Former Sr. Promotion Producer
