Apple ProRes HQ or Proxy for 4K material?
Kara Wayman
on Feb 19, 2013 at 9:46:32 pm
I am cutting some 4K material into a standard HD sequence, should I use ProRes HQ or Proxy to convert it?
Thanks!!
Kara
Shane Ross
Re: Apple ProRes HQ or Proxy for 4K material?
on Feb 19, 2013 at 10:04:39 pm
Proxy is for offline editing...it's low resolution. If you want high resolution, use HQ.
Shane
Little Frog Post
Kara Wayman
on Feb 19, 2013 at 10:22:26 pm
Thanks Shane!
When i use HQ I get an out of memory error message. I am cutting in High Res stock in preparation for the online edit. Suggestions?
Shane Ross
on Feb 19, 2013 at 10:37:52 pm
High res stock...Pictures? FCP cannot deal with still pictures with resolution over over 4000 pixels. YOu'll have to resize those.
Shane
Little Frog Post
Nick Meyers
on Feb 19, 2013 at 11:05:16 pm
so you wont be using this material in the on-line?
then it doesn't really mater what format you use.
i prefer LT. it's a small file size while still looking good.
proxy looks a little low-res for me,
but i generally need to project my cuts on a screen.
nick
