Sync problem on export
Jonathan Griffiths
on Feb 18, 2013 at 8:10:24 pm
I have a Proress timeline which plays fine with in FCP but when I export Quicktime one shot goes out of sync when I playback in Quicktime player the rest of timeline is fine. But if I re-import it it is fine in FCP. I have tried to recompress but it same result any surgestions gladly appreciated
Jonathan
Nick Meyers
Re: Sync problem on export
on Feb 18, 2013 at 10:58:24 pm
what format is the problem shot?
maybe it's a non-FCP standard format like H264.
thy can be unpredictably tricky.
if that's the case, then export or convert that shot, and re-inert it,
then try exporting.
nick
Jonathan Griffiths
on Feb 19, 2013 at 11:43:34 am
The shot in question is ProRes as is most of the sequence there are a few ProRes HQ 25fps and Pal-DV 25fps shots later in sequence but everything up to this point is full HD ProRes 25fps
Nick Meyers
on Feb 19, 2013 at 12:12:20 pm
ok, this reminds me of something i had a few years ago where the file did not have a stable TC track.
within FCP sync was fine, any export from a timeline was out.
the solution *from memory* was to batch export the clips, (same settings, self contained)
or maybe Media Manage them using Copy.
sorry i can't be more precise.
anyway the new files had an OK TC track, and would export properly
the problem started with a not so great "capture now" process direct from a telecine chain.
hope that helps
Jonathan Griffiths
on Feb 19, 2013 at 12:39:20 pm
Thanks for help we made another clip from the part we used shifted it by 5 frames exported as new QT re-imported problem solved but I am sure you are right about it being TC problem.
once again thanks
Joanthan
