lossless QT for re-import in FCP7
Nikhil Murthy
on Feb 11, 2013 at 8:45:42 pm
Hi All
I have a nested sequence that I want to make a variable speed change to. I understand this isn't directly possible in FCP7. Instead you have to export as a QT and re-import and change the speed on that clip.
I wanted to know what the best way to do this without losing any quality.
If found this post.
http://forums.creativecow.net/thread/8/1085793
Would you all say this is the best workflow for this?
Shane Ross
Re: lossless QT for re-import in FCP7
on Feb 11, 2013 at 9:35:41 pm
Yup. That's how you do it.
Shane
Little Frog Post
Nikhil Murthy
on Feb 11, 2013 at 9:57:36 pm
Great thanks for the tip and the OG post.
