Transcoding Nikon J2 slow motion footage to edit
Hannah Brown
on Feb 10, 2013 at 10:08:04 am
Hi all,
I was hoping someone may be able to help me figure out the best settings to transcode the NIKON J2 slow motion feature to edit in FCP 7?
It records in H.264 MOV/400fps 640x240
I have Apple Compressor and MPEG Streamclip to transcode.
Thanks for any help in advance!
Rafael Amador
Re: Transcoding Nikon J2 slow motion footage to edit
on Feb 10, 2013 at 11:17:37 am
Open the clips with MPGStreamclip. Make sure that the size is 620x240 (Unscaled).
Just need to uncheck "Interlaced Scaling". Use Prores as the conversion codec.
Then you need to conform the Prores clips (CinemaTools) to the time-base you want to edit with.
rafael
http://www.nagavideo.com
Hannah Brown
on Feb 13, 2013 at 9:20:34 am
Thanks Rafael!
