FINAL CUT PRO, APPLE COLOR, Reconnecting to original un-corrected media
Addison Mehr
on Feb 7, 2013 at 2:41:26 pm
Hi Cow,
I am editing in FCP and exported my project to Apple Color for a temp color correction...now I am looking to do a professional color correction and need to export an uncompressed file without color correction. However, I can't find the original un-color corrected FCP sequence!
Is there a way to relink the media in my sequence to the original source files (Apple ProRes 4444) ?
Thank you so much!
Addison
Shane Ross
Re: FINAL CUT PRO, APPLE COLOR, Reconnecting to original un-corrected media
on Feb 7, 2013 at 3:22:54 pm
Look in you Autosave Vault for earlier saved project files.
Shane
Little Frog Post
Andrew Kimery
on Feb 8, 2013 at 7:35:33 am
No, there is not a way to relink the sequence that came from Color to your original, uncolored media. Color creates all new media that is different in duration and filename from your original source media. Like Shane said, you need to find an older version of the project that has a pre-Color timeline in it.
