How to import REDCINE-X PRO .XML timeline into FCP
Justin Viney
on Feb 6, 2013 at 9:50:09 am
Hey there,
I have been trying to familiarize myself with the REDCINE-X PRO, FCP workflow with RED footage. I am playing with some 4K RED ONE footage and find myself running into trouble when starting an online edit. I couldn't find my solution on the net since everyone seems to operate differently when it comes to RED workflows so I thought I'd ask the forum myself.
My steps here are as follows:
(Let me know if I am doing anything wrong.)
- Import R3D files into REDCINE-X PRO
- Export proxies (1280x720 AppleProRes(LT) with 1/4th Debayer setting)
- Import and edit proxies in FCP
- Export the offline edit out as an .XML
- Import the .XML into REDCINE-X PRO and the R3D directories.
- Export Timeline (allclips) as QuickTime Wrappers, generate FCP .XML enabled.
- Import .XML in FCP
Now here is where I run into my issue. The dimensions of the sequence are all incorrect and need to be rendered, despite the settings I choose when importing the .XML. I want my online to be in 2K but I am not sure how to do that exactly. I read to use Quicktime Wrappers generated in REDCINE-X to connect the .XML but doing so I can't seem to figure out how to configure the resolutions and adjust the debayer settings.
Thanks for your time.
Justin
Rafael Amador
Re: How to import REDCINE-X PRO .XML timeline into FCP
on Feb 6, 2013 at 3:15:27 pm
I've never worked with that stuff, but what i see is that in the upper still (Edit Preset), you have selected "1920 x 1080" (QT Wrapper), which is HD but not 2K.
I guess you should set there 2K.
rafael
http://www.nagavideo.com
Justin Viney
on Feb 7, 2013 at 5:27:23 am
Hey thanks for your response.
All the settings appear to be locked when selecting QuickTime Wrapper.
