Best settings for 720p YouTube
Joe Hubbard
on Feb 2, 2013 at 4:44:47 am
My 90 second video is a 720p 23.98 ProRes. I'm going to convert it using Streamclip.
Going to make an H.264, set the limit data rate to 30,000kbps, and up the quality to 100%. Keep all the sizing as frame rates same as source.
Are these the best settings?? Will having 30,000kbps make it longer to load the video??
I can't find specific answers to the kbps question, so any and all info will help!!
Thanks!!
Joe
Bret Williams
Re: Best settings for 720p YouTube
on Feb 2, 2013 at 5:15:00 am
If you're not an expert at this encoding thing, why not click the share button, click the youtube button, and choose 'better quality" and be done with it?
Bret Williams
on Feb 2, 2013 at 5:15:50 am
Wait wrong FCP. Export to compressor and choose the youtube setting there. They had that in compressor 3, right?
David Roth Weiss
on Feb 2, 2013 at 5:59:43 am
YouTube now accepts ProRes. Just upload and let the YouTube encoder have its way with your master.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Bret Williams
on Feb 2, 2013 at 6:51:37 am
And a a gig a minute, that's some long upload! At 3Mb/sec, a normal video would take all night.
Rafael Amador
on Feb 2, 2013 at 10:08:28 am
Prores (1280x720) is around 100Mbps, so at 3Mbps upload speed, would take 33,3 seconds to upload one second of the movie.
Joe's clip is 90 seconds. so that would take 90 x 33,3 seconds = 2.997 seconds to be uploaded.
That means 49 minutes and 57 seconds.
YouTube recompress everything you upload, but the better the source, the better the quality when streaming.
I guess that for showing a clip to your friends is not worth an almost one hour upload, but if you are making money with your YouTube videos probably is worth.
With my 500 Kbps (1Mbps late at night) I can not dream on uploading Prores.
rafael
http://www.nagavideo.com
Chris Tompkins
on Feb 4, 2013 at 12:07:38 pm
Chris
John Norris
on Feb 4, 2013 at 12:34:09 pm
Going straight out of FCP, you will easily get it to 5000Kbps in H.264, Multipass will further improve quality but takes longer, These will work fine for 720p Footage, Also isnt bad with 1080p
John Norris
johnnorris@topblokesproductions.co.nz
http://www.topblokesproductions.co.nz
