Can't update FCP 7 to 7.03 in ML
Justin Crowell
on Feb 1, 2013 at 9:22:35 pm
Hi All,
I'm working on a brand new ML Mac Pro. I installed FCP 7, but am unable to update it, as those updates don't come through the App Store. I DLed and installed the pro apps update (here)but all apps are still reading as their original installed versions.
I DO have FCP X, Compressor 4, and Motion installed, and so have all of the FCS3 stuff in its own folders. Could that be the problem?
J
Video editor, animator, composer, producer
JustinCrowell.com
Shane Ross
Re: Can't update FCP 7 to 7.03 in ML
on Feb 1, 2013 at 9:44:59 pm
You don't go through the app store. FCP 7 was never sold through the App store. You use SOFTWARE UPDATE to get the update for FCP 7
Shane
Little Frog Post
David Roth Weiss
on Feb 1, 2013 at 10:49:23 pm
First, when you install from the original disc you shouldn't move any of the folders from their default locations.
Second, you should update by clicking on the Apple at he upper screen left and using Apple Software Update, as there are numerous componenet updates that may have to happen before FCS updates, and it's virtually impossible to do the updates manually.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Paul Jay
on May 29, 2013 at 10:02:39 am
First you need to update them , before you put them in a seperate folder.
Install FCS3 , then go to appstore/software update ( ITS THE SAME on 10.8 )
Then create a folder to put them in , so you can install FCPX.
