Effected Still Preview looks different from rendered version FCP 7.0.3
Peter Simon
on Feb 1, 2013 at 5:10:55 pm
I'm at a new job... with a new computer with FCP 7.0.3. I'm trying to color correct some footage in the timeline using 3-way CC. eyeball the footage and use the sliders to take the blacks down until right before losing detail and the whites up... using the Canvas preview. Then when I render, it renders out darker than what I was just seeing. I can't figure out what is happening. This never happened on any other FCP I've used. I have a computer at home and used FCP at my old job. Neither have done this. Any suggestions?
Shane Ross
Re: Effected Still Preview looks different from rendered version FCP 7.0.3
on Feb 1, 2013 at 5:44:01 pm
What is the codec of this said footage?
Shane
Little Frog Post
Peter Simon
on Feb 1, 2013 at 6:01:19 pm
Sorry... I'm working with H.264 from a Canon T2i. This was the first time in a while that I edited footage straight from the camera. Usually I convert it to ProRes first, but I didn't think I had time for that with this project.
Shane Ross
on Feb 1, 2013 at 6:05:41 pm
I KNEW IT!!!
And now you see why you need to convert to ProRes before you edit. FCP and H.264 don't mix. And you even knew better, but did this anyway! :)
Want to edit native without converting? Get PRemiere Pro.
Shane
Little Frog Post
Peter Simon
on Feb 1, 2013 at 6:09:43 pm
I had an inkling that might be the problem, but wasn't sure. Thanks for the confirmation.
