Apple Compressor
fernando zuniga
Apple Compressor
on Jan 30, 2013 at 3:13:22 pm
Hello
I would like to know how to get rid of these lines (around the edges): they show mainly where there's movement happening in the image.
Shane Ross
Re: Apple Compressor
on Jan 30, 2013 at 3:40:18 pm
Click on the drop down menu box on the top of the Canvas...the right most one, that has a box icon. Click on that and deselect SHOW OVERLAYS.
Those are the TV safe and Title safe guides.
Shane
Little Frog Post
fernando zuniga
on Jan 30, 2013 at 3:52:03 pm
Thanks Shane, but what about when the project goes to compressor what settings do I need to change, cause before I didn't change nothing, when I put the movie on my new Samsung LED I saw lots of jagged lines, I mean the quality was poor.
fernando zuniga
on Jan 30, 2013 at 3:54:06 pm
Thanks Shane, but what about when the project goes to compressor, the movie looks like 3D movie with out the 3D glasses.
Shane Ross
on Jan 30, 2013 at 3:58:46 pm
OH...sorry.
Well, I see those sequence settings, but what are your clip settings? What codec are you dealing with? Did you have to render that when you added it to the sequence?
And you don't say anything about what settings in compressor you are using.
Shane
Little Frog Post
fernando zuniga
on Jan 30, 2013 at 4:15:07 pm
Thanks Shane, but what do you mean by clip settings? and as fas has Compressor, Im using Dvd best quality 150min. And I render everything, when I got done with the project.
Thanks for helping me Shane.
Shane Ross
on Jan 30, 2013 at 4:25:13 pm
Your footage. What camera was the source footage shot on? How was it captured? To what codec? Your captured media are CLIPS, so what are your CLIP settings? Do they match the sequence settings?
Right click on a clip in the timeline and choose ITEM PROPERTIES. Or look in the Browser under COMPRESSOR
Shane
Little Frog Post
fernando zuniga
on Jan 30, 2013 at 4:34:57 pm
Yes, Shane. To capture I used Sony HDV FX 1000, and at first I used HDV 1080i60, then on Sequence settings on quick time video settings, I change the compressor to HDV 1080p30.
Shane Ross
on Jan 30, 2013 at 4:44:50 pm
YOu shot 1080i60? So your footage is interlaced?
Hmmmm...well, your sequence settings, while they say 1080p30, still say UPPER FIELD in dominance. Switch that to NONE and see what happens. You will have to re-render.
Shane
Little Frog Post
fernando zuniga
on Jan 30, 2013 at 4:51:52 pm
I sure will Shane and hopefully will work, thanks Shane, have a good one.
fernando zuniga
on Jan 30, 2013 at 6:42:30 pm
Hey Shane, still rendering, now, what do you recommend, should I export via compressor or as a QT file and what presets, or what settings should I change on the compressor ? Thanks.
Shane Ross
on Jan 30, 2013 at 7:16:59 pm
For making a DVD, I always export a self contained QT file, using the sequence settings. Take that into Compressor, use the DVD BEST QUALITY preset...and take the result into DVD Studio pro for authoring.
Shane
Little Frog Post
fernando zuniga
on Jan 30, 2013 at 11:59:40 pm
Hey Shane should I move anything on the interlaced in Compressor?
Shane Ross
on Jan 31, 2013 at 12:01:42 am
Well, if your footage isn't interlaced (is the source footage interlaced?) then you shouldn't need to deinterlace in Compressor. Heck, even making that sequence setting should have gotten rid of it.
Try doing nothing about it in Compressor...see what happens.
Shane
Little Frog Post
fernando zuniga
on Jan 31, 2013 at 12:05:41 am
Ok, I will.Thanks.
fernando zuniga
on Jan 31, 2013 at 12:19:28 am
Shane, so from now on how do I capture HDV, since I film with a HDR-FX1000
I have FCP-Avid & Adobe Premiere. Thanks!!!!
fernando zuniga
on Jan 31, 2013 at 9:49:05 pm
Hey Shane ur advice work!! thanks a million.
Just 1 question, on Compressor should I leave everything alone in frame control ?
Shane Ross
on Jan 31, 2013 at 10:39:22 pm
Yes. Unless you are changing frame rates or frame sizes...leave that alone.
Shane
Little Frog Post
fernando zuniga
on Feb 2, 2013 at 3:43:35 pm
Hey Shane, the project that I compress is done, but the HDV quality is not there, how do I compress it and burn it , to keep the HD quality.? Thanks.
Shane Ross
on Feb 2, 2013 at 4:45:13 pm
Ah. For that you need to author a BluRay disc. DVDs are SD only. So now you need a BluRay burner, BluRay software like Roxio Toast or Adobe Encore. And then a BluRay player to watch it on.
Shane
Little Frog Post
