Had a 32 GB SD card stop recording while shooting
Scott Herriott
on Jan 29, 2013 at 4:22:47 pm
It was 2/3's full and I desperately need to get the footage off of it. When I put it in my IMac's side slot, Log and Transfer is not reading it. I'm using FCP 7.0.3.
I've found some software that looks like will possibly extract the files (Rescue 4).
But, how then is the conversion to Apple Pro Res done?
Any suggestions appreciated.
Thanks in advance,
Scott
Rafael Amador
Re: Had a 32 GB SD card stop recording while shooting
on Jan 30, 2013 at 6:20:34 am
[Scott Herriott] "But, how then is the conversion to Apple Pro Res done?"
If you are able to save the .MTS or whatever that camera records, you can use 5DtoRGB or ClipWrap to convert the files to Prores.
rafael
http://www.nagavideo.com
