DV export from qt7 is incorrect size?
sean miller
on Jan 20, 2013 at 1:00:15 am
I'm being asked to deliver some video in dv25, don't have any previous experience with this codec as 90% of my work is for the web so did a bit of googling and found that DV, DVCam, DVCPro and Digital 8 are ALL DV25 formats... So I'm not sure which to use, I'll contact them and ask for specifics
But for now, I tried exporting at DVCPRO 1024x576, 25 fps using quicktime pro 7 (source is in pro res is 1920 x 1080 ) following this tutorial which refers to "dv25" as "dvcpro ntsc"
http://www.tunecore.com/images/video/dv25_tutorial.pdf
However for some reason, the exported video is smaller ?
http://i.imgur.com/gUYegmN.png
Also - if i try to export using "dv stream" in compressor, the size option is greyed out and forced at a smaller size - http://i.imgur.com/ZA2N8C1.png
Can anyone point me in the right direction here?
Cheers
Rafael Amador
Re: DV export from qt7 is incorrect size?
on Jan 20, 2013 at 3:27:29 am
Pal DV is 720x576.
The only problem is that QT do not display other than Squared pixels and the picture looks distorted.
So if the picture is to be displayed on computers, is OK that you make 1024x576, but if you have been asked standard DV, leave it at 720x576.
The picture will be properly displayed when interpreted as PAL DV Anamorphic.
rafael
http://www.nagavideo.com
sean miller
on Jan 20, 2013 at 4:12:15 am
Thanks, I'm not sure whether they want PAL or NTSC (I'll ask), is NTSC also default to 720x576?
The project is being played on some sort of projector, what confuses me given your info though is that they asked for
"dv25 at 1024x576"
Is this an impossibility?
Rafael Amador
on Jan 20, 2013 at 11:12:20 am
If you are working at 25fps you are in PAL lands.
NTSC is 720x480 (DV formats), or 720x486.
rafael
sean miller
on Jan 20, 2013 at 3:19:30 pm
Ok thats what I thought, I just tried exporting the 1920x1080 pro res using qtpro 7
Settings :
DVCPRO - PAL
frame rate : 25
Scan mode : Progressive
Aspect : 16x9
Size: 1024 x 576
and it came out at 1024 x 576 :)
Thanks man, I have to say some of the colors are a bit off on logos etc, but I guess thats just the DV compression
Steve Eisen
on Jan 20, 2013 at 4:50:15 pm
Give them a DV-Pal QT. They will handle the rest. The switcher they are using will rescale it for the projectors.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Rafael Amador
on Jan 20, 2013 at 5:54:09 pm
[sean miller] "Settings :
DVCPRO - PAL
frame rate : 25
Aspect : 16x9
Size: 1024 x 576
and it came out at 1024 x 576 :)"
Sure, that will look perfect on your computer, but is not standard DV.
If the movie will be reedited with other DV stuff, broadcasted or used for a DVD, it wont pass.
AND DON"T USE DVCPRO, that's a completely different codec.
Use Apple DV PAL.
rafael
sean miller
on Jan 20, 2013 at 7:04:54 pm
Ok I think thats pretty much what I sent them on the first go around. They came back specifically asking for 1024x576 anamorphic in dv25
I just exported the pro res again as DV PAL, 1024 x 576, progressive
These are the results when I 'get info' in qt : http://i.imgur.com/ZbHoTzo.png
Whilst it says 1024 x 576 (actual) in the format area it says 720x576 and (1023x576).... really confused here.
Bret Williams
on Jan 20, 2013 at 8:05:40 pm
Actual is the size that is being shown. But the encoded pixels are 720x 576. DV is a fixed codec (s). 720x480 or 720x576. Anything else and you'll get errors or problems. When you encoded your 16x9 it squeezed it horizontally into 720x576. The computer sees that it has an anamorphic tag and displays it correctly at 1024x576.
sean miller
on Jan 20, 2013 at 8:14:02 pm
Ah ok thanks that makes sense.
Given that they've asked for 1024x576 - to be played on a projector. Is it more likely that what they actually want is 720x576?
I'm assuming a projector won't see the anamorphic tag the computer sees and display the video with dodgy looking proportions.
Thanks for the help, much appreciated
Steve Eisen
on Jan 20, 2013 at 10:41:06 pm
Create what I said. They will scale it up to their dimensions
Steve Eisen
Vice President
sean miller
on Jan 20, 2013 at 10:52:01 pm
Yeah thats what had me confused as I originally sent a Pal DV and they sent back saying "note we require 1024x576 in dv25"....
Are you suggesting i should just send over the original size pro res source (1920 x 1080) converted to pal dv without resizing.
Or send it in 720x576 pal dv?
Or could they possibly mean HDV format?
Rafael Amador
on Jan 21, 2013 at 2:15:02 am
Don't worry about what that window say.
720x576 and 1024x576 is the same frame but made out of different pixels, the first PAL-Anamorphic, the second Squared. Any projector should be able to display both without problem.
Anyway, if they asked you 1024x576, do that.
Use QT and export 1024x576.
rafael
sean miller
on Jan 21, 2013 at 9:46:30 am
I used QT, exported PAL DV - 1024 x 576. Progressive.
They are mentioning that playback on their PC they get the wrong aspect ratio : http://i.imgur.com/JNmMsOE.png
Whereas on mac its fine: http://i.imgur.com/iVJCYsd.png
Its clear to me that whats happening is on mac the computer sees the anamorphic tag and displays the video at the correct 1024 x 576 whereas on PC its not & displaying it at 720 x 576, which messes up all the proportions of the video.
Just found out its not a projector they use but a giant LED screen.
Their PC"s are really old so that might be the issue, my concern is that will it play back ok (seeing the anamorphic tag) on the giant LED as it does on the mac... and not as it does on the PC?
