How to zoom smoothly?
benjamin pollock
on Jan 17, 2013 at 2:20:17 am
It seems when I zoom using keyframes from say 0 to 400% over a 10 second period of time that from 0 to 100% or so it zooms very fast and then from 100 to 400 it seems like the effect is way slower. Is there any way to zoom in such a way that the rate appears even? I'm sure it is technical even, just that when the image gets larger, the same incremental increase doesn't appear to have as much an effect.
Shane Ross
Re: How to zoom smoothly?
on Jan 17, 2013 at 5:24:21 am
YOu need to use another app that does this properly. Like Motion or After Effects.
Shane
Little Frog Post
benjamin pollock
on Jan 17, 2013 at 5:31:27 am
thanks a million Shane!
