Keeping externally recorded audio synced up with long video interviews? Drifting Audio Challenge!
Jamie Bianchini
on Jan 16, 2013 at 5:04:24 am
I did a LOT of long interviews and recorded audio on a field recorder. when i sync up with hand clap all is well for first few minutes but then it starts to drift by the middle and end of interview. I assume i used different audio rates or something (i am a rookie, i admit). has anyone come out with some software that mirrors the two in some way? i will only use 30-90 seconds out of each 20-40 minute interview. so i just was wondering if anyone had any ideas, solutions, suggestions as it's taking so so much time to slide the audio left and right when i find the areas i want to use and have good audio.
Thoughts?
Thanks much!
Jamie
Rafael Amador
Re: Keeping externally recorded audio synced up with long video interviews? Drifting Audio Challenge!
on Jan 16, 2013 at 10:20:55 am
Up to a recent post (http://forums.creativecow.net/thread/200/896802#896802), can be some issues when making long audio recordings.
rafael
http://www.nagavideo.com
Simon Modery
on Jan 16, 2013 at 10:34:43 am
There is also the possibility that your video is running at the wrong frame rate (resulting in faster or slower playback). Right-click on a clip in the timeline, then go Properties > Format and check the vid rate.
Is it the same you recorded your material in?
What camera did you use?
Head of Postproduction
Motherlode
http://www.motherlode.org.uk
http://www.simonmodery.com
