Final Cut Pro Firewire Problem?
William T
on Jan 14, 2013 at 5:34:24 am
Last week FCP6 on G-5 PwerMac stopped recognizing Firewire connection. Changed to new cable and tried with several cam-corders - still no luck. Any suggestions?
Dave Farrants
Re: Final Cut Pro Firewire Problem?
on Jan 14, 2013 at 8:21:53 am
I had this happen with a G5, took a generic cheap 3 xFireWire input PCI card from a PC and installed it in a spare slot, worked a treat.
Web - http://www.foxvideo.co.uk
Blog - http://foxvidpro.blogspot.co.uk/
Shane Ross
on Jan 14, 2013 at 8:41:16 am
I concur. You've changed the cables, and the camera...so the culprit has to be the ports. They went bad.
Shane
Little Frog Post
William T
on Jan 14, 2013 at 4:53:17 pm
I put in a Firewire PCI hub card and connected my external hard drives. They work fine but still nothing to the cameras.... Should I reinstall FCP?
Alan Okey
on Jan 15, 2013 at 4:33:14 pm
Trash your FCP preferences. It's quite common for a corrupted preference file to be the cause of non-working FireWire in FCP.
William T
on Jan 15, 2013 at 8:07:32 pm
How exactly do I trash them? Are these the preferences listed after the program is open or is a preferences folder in the system folder?
William T
on Jan 16, 2013 at 4:15:38 pm
Thanks. I trashed the FCP Preferences and verified hard drive- restarted and it still does not recognize the firewire.
Bill
