Marking clips in Final Cut 7
Jamie Bianchini
on Jan 13, 2013 at 11:48:08 pm
I'm editing lots of long interviews and I need to mark various sections to go back and edit so I was thinking of using a marker on the clip itself. If i hit "M" it marks the timeline location but not on the clip itself. Is there a way to put markers so they show up on the actual clip? the "M" feature is fine but if i move the clip that marker does not move with it. Thanks!
Jamie
Shane Ross
Re: Marking clips in Final Cut 7
on Jan 14, 2013 at 7:47:37 am
If you want the marker to be on the clip, you need to load the clip into the VIEWER and watch it there.
Shane
Little Frog Post
Jamie Bianchini
on Jan 14, 2013 at 8:49:21 am
Thanks, Shane. That should do the trick! Much appreciated!
Jamie
Matt Faw
on Mar 15, 2013 at 6:24:13 pm
Hi Jamie,
You can also add the markers to the clip itself, while playing in the timeline, but the clip needs to be highlit first.
Matt Faw
Consciousness 3D
