23.98 exported pro res time code issues
Arran Essex
on Jan 13, 2013 at 10:56:33 pm
Hi
I've been working with some 23.98 material. The issue I am having is that when exported and viewed back in quicktime the bars, clock and program timecode starts have shifted by 1 frame, 2 frames & then 3 frames ending with a second difference in duration then should be.
But when I drop the file back into fcp all the bars clock and programme start sync up correctly.
I've checked back a load if old 23.98 files I have and they are exactly the same.
This is only an issue with 23.98 all my 25 files are correct.
Hopfully some one has come across this and can help I've tried everything and must be missing something.
