Upgrade to Mountain Lion
fernando zuniga
on Jan 10, 2013 at 9:06:29 pm
Is FCP 6 And Avid compatible with Mountain Lion?
Shane Ross
Re: Upgrade to Mountain Lion
on Jan 10, 2013 at 9:37:27 pm
Avid MC 6.5 is compatible. As is Avid MC 6.0.3
FCP 6 is not. It won't even install. The installer is PowerPC based, and Mountain Lion doesn't have Rosetta...that allows PowerPC apps to work. You might be able to CUSTOM install Rosetta from Snow Leopard. But FCP 6 is VERY old software, and old software and brand spankin' new Operating Systems don't generally mix well. (FCP 6 is 6 years old, ancient in software world)
Shane
Little Frog Post
fernando zuniga
on Jan 11, 2013 at 4:59:02 pm
Thanks Shane, ok, but what if I already have FCP & Avid install.Can I still upgrade?
Shane Ross
on Jan 11, 2013 at 11:02:06 pm
FCP 6 might work. As for Avid...only Media Composer 6.0.3 and 6.5 are "compatible." Meaning those are the ones that are tested and certified solid by Avid. Other versions aren't rated to work with ML...so you might have issues.
Shane
Little Frog Post
