Prores files to big - video for internet quailty not needed
Charlie Willmott
on Jan 10, 2013 at 3:23:39 pm
I have some mpg files and I'm currently converting them to prores LT (lowest quality), with mpeg streamclip, so I can edit them with final cut - but my hard drive is running out of space. The quality of the files don't matter so does anyone know a small file type supported by final cut? Or any options I should tick on mpeg streamclip to make the file smaller?
Regards,
Charles.
Rafael Amador
Re: Prores files to big - video for internet quailty not needed
on Jan 10, 2013 at 3:59:33 pm
You can use PhotoJPEG.
Lowering the quality slid you will reduce the file size.
rafael
http://www.nagavideo.com
Shane Ross
on Jan 10, 2013 at 6:06:07 pm
ProRes Proxy is decent quality. The Photo JPEG Rafael refers to is called "Offline RT" or "Offine RT HD," and is a VERY low quality codec meant for offline editing only...meaning that later you will reimport/capture the footage at higher resolution later. It isn't a finishing format.
Shane
Little Frog Post
