aligning numbered images to markers in FCP sequence
Matt Kalman
on Jan 9, 2013 at 8:07:06 pm
i am looking for a magic trick here.
basically (in fcp7) i want to insert numbered images into a sequence based on markers. (ie: i have a folder with Slide01.png, Slide02.png, Slide03.png, etc. and i want an easy way to throw it in a sequence so that Slide01.png lines up with Marker 1, Slide02.png lines up with Marker 2, Slide03.png lines up with Marker 3, etc.
any tricks?
Mark Suszko
Re: aligning numbered images to markers in FCP sequence
on Jan 9, 2013 at 8:21:47 pm
Are the markers all of the same duration? I was thinking, you can manually alter the duration of each still while they are in the bin together, then lasso the entire group and drag it to track 2 video and they would more or less be lined up that way? If the markers were all the same duration, you can just set the bin itself to import the stills and assign the preset duration.
