XML Translation was aborted due to a critical error
Jeff Griswold
on Jan 3, 2013 at 4:40:15 pm
I've been exporting xml's from old projects (FCP 7) and had great success. However, a few projects get the xml translation error when I am trying to export. I've searched the web and can't find a real answer. The project files are only 27 mb.
Any ideas?
Thanks in advance.
Jeff
Jeff Griswold
Re: XML Translation was aborted due to a critical error
on Jan 3, 2013 at 7:37:48 pm
I figured out the answer to my post and thought I would share it with you. I found that if there is a user defined effect, i.e. dissolve in the project panel, then FCP will fail in its attempt to create the xml file. By removing the effect FCP creates the xml without any issue.
I hope this helps you.
Jeff
ILan Azoulai
on Aug 7, 2014 at 6:37:51 pm
Thank you for that.
Also, if there are characters in ANY of the fields in the file description in the browser, FCP will get the error.
Joshua Stenseth
on Aug 3, 2017 at 7:00:25 pm
Can you explain more what you mean by this?
