DVD Studio Pro install on Lion
Paul Domanchuk
on Jan 3, 2013 at 12:29:49 am
I just got a new MacPro with Lion and FCPX. I have FCP Studio 2 with FCP 6. I really like using DVD StudioPro and would like to continue authoring DVD's and BluRays using it. However, when I tried to install I got the message that PowerPC apps cannot be installed. How can I get it installed? Is there a better program for authoring DVD's if I can't.
I know that Apple thinks everything should be posted to the web but I still have clients who want DVD's with a nicely authored menu. What can I do?
Neil Patience
Re: DVD Studio Pro install on Lion
on Jan 3, 2013 at 7:25:31 am
Hi Paul
This is something that has come up a few times recently, people wanting to instal FCP6 etc on Lion or ML.
Apparently it can be done.
I think this is the thread you need
(but if not have search for FCP6 on Lion/ML you should find more info.)
http://forums.creativecow.net/thread/8/1169455#1169455
best wishes
Neil
http://www.patience.tv
Paul Domanchuk
on Jan 3, 2013 at 6:03:32 pm
Thanks, I did look at that thread and will attempt to install DVD Studio Pro that way. But since DVD Studio pro has been discontinued, what are my other choices that are current that I can make a professionally authored DVD?
Neil Patience
on Jan 3, 2013 at 7:07:45 pm
I was in a similar position in that although I have DVD Studio as part of FCP7 I needed to make some BluRay discs.
I tried Toast 11 (I think) and had issue burning BluRay disks so ditched that, luckily I tried it out on a friends Mac so didn't have to buy it.
So I ended up getting Adobe Encore. Sadly not a stand alone app but part of CS 5.5 in my case. It works in a similar way to DVDSP so its easy to pick up workflow wise and along with a simple Samsung portable BluRay burner have had no real issues.
Adobe Media Encoder, which is part of the same suite also works well and I have tended to use that over Compressor of late, (obviously have to for BluRay)
I only tend to make fairly simple discs, usually no more than a couple of menus and a few choices of content at the most.
I know there are a few other stand alone app options so it might be worth posting in the DVD Authoring forum to get more specifics on that.
best wishes
Neil
