slow rendering - suggestions?
Dan Veltri
on Dec 31, 2012 at 8:55:27 pm
Hi Folks,
Sorry for the long post here, but I know that y'all can't give me any advice unless you know all the details. So here's the situation:
I'm using FCP 7.0.3. I produce short educational media pieces and do a lot of subtitling. I've been shooting with a GH2 and loving it, and always edit the AVCHD footage using ProResLT. The problem is every time I add a new subtitle (on the same video track) I need to render it. Here are my system details:
Running Snow Leopard 10.6.8. I use a lot of After Effects and just joined Adobe's Cloud Program...thinking about slowly migrating to using Premiere Pro.
My questions:
1- how can I avoid these constant renders? Do I need a new graphics card? Heard lots of good things about the Quadro 4000. Thoughts?
2 - the Maxx Digital RAID is only using the FireWire 800 connection now. At the time I purchased the RAID, the e-SATA card was not working with my system. Would solving that issue and using the e-SATA connection solve my speed issues?
Thanks in advance for your time - and Happy New Year!
--Dan Veltri
Producer
Treehouse Video
Hardware Overview:
Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.66 GHz
Number Of Processors: 1
Total Number Of Cores: 4
L2 Cache (per core): 256 KB
L3 Cache: 8 MB
Memory: 8 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: MP41.0081.B07
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5
Serial Number (system): H09430V94PD
Serial Number (processor tray): J5939016X4MFE
Hardware UUID: A85D70BD-3D1C-511D-ACF5-0FC15765E93D
ATI Radeon HD 4870:
Chipset Model: ATI Radeon HD 4870
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: ATI (0x1002)
Device ID: 0x9440
Revision ID: 0x0000
ROM Revision: 113-B7710C-176
EFI Driver Version: 01.00.318
Displays:
LCD200VX:
Resolution: 1344 x 1008 @ 60 Hz
Pixel Depth: 32-Bit Color (ARGB8888)
Display Serial Number: 48101067QA
Mirror: Off
Online: Yes
Rotation: Supported
LCD200VX:
Display Serial Number: 4X103203QA
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
FireWire Bus:
Maximum Speed: Up to 800 Mb/sec
Built-in Hub:
Connection Speed: Up to 800 Mb/sec
OXFORD IDE Device 1:
Manufacturer: Oxford Semiconductor Ltd
Model: 0x0
GUID: 0x30E002E0A08890
Sub-units:
OXFORD IDE Device 1 Unit:
Unit Software Version: 0x10483
Unit Spec ID: 0x609E
Firmware Revision: 0x100
Product Revision Level: 0
Sub-units:
OXFORD IDE Device 1 SBP-LUN:
Capacity: 3 TB (3,000,461,058,048 bytes)
Removable Media: Yes
BSD Name: disk2
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Not Supported
Volumes:
Capacity: 209.7 MB (209,715,200 bytes)
Writable: Yes
BSD Name: disk2s1
THMaxx1:
Capacity: 1 TB (1,000,153,686,016 bytes)
Available: 571 GB (570,997,809,152 bytes)
Writable: Yes
File System: HFS+
BSD Name: disk2s2
Mount Point: /Volumes/THMaxx1
THMaxx2:
Available: 582.93 GB (582,928,793,600 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk2s3
Mount Point: /Volumes/THMaxx2
THMaxx3:
Capacity: 999.54 GB (999,541,276,672 bytes)
Available: 443.74 GB (443,739,410,432 bytes)
Writable: Yes
BSD Name: disk2s4
Mount Point: /Volumes/THMaxx3
Mark Suszko
Re: slow rendering - suggestions?
on Dec 31, 2012 at 10:36:41 pm
My first guess is that your sequence settings and import settings don't agree. It happens. Compare them side by side using "get info".
Happy New Year, hope that fixes it.
Jeff Meyer
on Jan 1, 2013 at 10:21:55 am
Do you have unlimited RT turned on?
