Client Wants Multiple Frames of people saying lines in sync.
Ned Miller
on Dec 27, 2012 at 11:26:25 pm
I assume that some of you have been requested to do this before so I'd appreciate any advice. A client has employees all over the globe and wants them to do a Skype, or I suppose it can just be a captured video, saying something that is THE EXACT SAME LINE as everyone else, then wants them to be in their own box (ala Brady Bunch) but may want up to 40 frames. Almost like a mosaic.
I will instruct them to look at the camera for 5 seconds before and after delivering their line, add a smile at the end. I will send out instructions as to framing, background,etc and may send out a 10 second example of me doing it so they know the pacing. I believe the line is just five words.
My question is: If the client wants a LOT of people simultaneously on screen do you know of any templates? Any advice? Is there any appreciable difference between having them do a Skype session vs just doing a video and sending it? I realize with Skype we can "direct" them a bit.
Many thanks,
Ned
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.com
Mark Suszko
Re: Client Wants Multiple Frames of people saying lines in sync.
on Dec 28, 2012 at 3:19:56 am
Can't help with the templates. I foresee lighting and audio problems. I do urge you to have them all perform to a pre-made sample audio track, so they all have close to the same rhythm and pace. Each should do more than just the short line, they should have some "handles" on either side of their take.
As to lighting: the Skype users will be close to their monitors and probably NOT looking directly into the webcam. You will likely have backlighting probe, screen reflections on glasses, funky color temps on faces due to screen colors, and weird lighting due to most light coming off the screen. For audio, those wearing a headset will sound right, the rest will be far off-mic.
The real camera users will have better resolution, but lord knows what they will have for audio, likely the on-camera shotgun, and a roulette wheel of lighting and framing choices. I don't envy the post tasks you have. It sounds like it will look cool, but behind the scenes, this is a bear to put together with good sound and color grading, your template is the least of the problems, I think.
David Eaks
on Dec 28, 2012 at 11:14:16 am
There's also the issue of trying to work with 40 tracks of video stacked up. You could build it in several sections with just a few of the clips each, then export each section and bring the new files back in to put it all together.
Steve Eisen
on Dec 28, 2012 at 2:50:56 pm
Happy Holidays Ned. There are no templates that I know of. Depending on how many faces you want to see on the screen at a time, resize your clip and place on video layer. Copy and paste attributes then move the clip over. Repeat till you fill your screen.
There is a video tutorial on how to do this.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Kevin Camin
on Dec 29, 2012 at 7:24:58 am
This is definitely more in the realm of motion design and fx work than editing. This would be so much easier to do in After Effects in terms of getting 40 squares on screen. You could do really cool things like have a 3D camera swooping around the squares at a dynamic angle and then pull back to reveal all the squares at once for a climactic finish.
I also think you are going to have to do an extraordinary amount of work to make these people look good. 99% of people don't know what lighting looks good or how to frame themselves properly. They can have a reference image right next to them, but I bet most will not be able to replicate it well. They are busy, probably don't want to do this, and are not visually literate people. My point is that your creative director or whoever should be firmly aware this could very well turn into a nightmare, and it will not instantly look very good without a lot of the budget going into repairative work and some of the videos might be unusable.
I work as a motion designer and do some editing. I've been to a few rodeos and these user generated videos are always a hard drive full of s#it. People are trying to save a buck by not hiring professionals to shoot testimonals or sound bites, but then spend an inordinate amount of money in post just to make the footage digestible. It is a mistake in my opinion to work this way. They just need to hire a camera guy or gal to go down to the company and replicate the look of web cam footage, but provide you with a clean and clear, well exposed video.
Good luck. I'm not really complaining because I get more work or hours with user generated footage, but I fully recognize it's usually not the best work practice.
Best regards,
Kevin Camin
