2 frame rates
Scott Duncan
2 frame rates
on Dec 21, 2012 at 9:51:43 am
I shot wedding w/ Sony Z5; initially (1st tape) in DV widescreen (30 fps) but tapes 2, 3 & 4 were shot 1080p 24 fps.
Big mistake; obvious now.
Edited all in FCP 6. In trying to cut & paste sequences together I get " cannot nest sequences with different editing timebases".
I have 23 min.intro/ ceremony sequence (DV widescreen) as stand alone QT mov now.
How can I best convert that and/ or merge it w/ 62 min. 24 fps sequences, or perform other action to unite the diff frame rates into one, w/ best looking quality for a DVD for the bride & groom?
3 Ghz Intel Core 2 Duo MBPro / 8 GB / OS 10.6.8 / FCP 6.0.6
Stephen Smith
Re: 2 frame rates
on Dec 21, 2012 at 2:54:02 pm
Which version of FCP are you on? You can mix frame rates and sizes in one timeline. I do it all the time.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Scott Duncan
Re: 2 frame rates
on Dec 21, 2012 at 4:14:50 pm
William Carr
Re: 2 frame rates
on Dec 23, 2012 at 8:35:36 pm
Individual sequences with common frame rates can be added individually onto the DVD. But if you need to merge different frame rate clips on one sequence I find it's better to convert the slower rate clips up to the higher clip rate.
