Flash animation into FCP
Paulo Marques
on Dec 20, 2012 at 5:18:27 pm
Hello,
If someone can help me, i would like to export a flash animation into FCP or a similar just to add background sound..
Wich is the best for me, to export a flash animation for the web?
Many thanks for you all.
Rafael Amador
Re: Flash animation into FCP
on Dec 21, 2012 at 2:21:57 am
[Paulo Marques] "If someone can help me, i would like to export a flash animation into FCP or a similar just to add background sound.."
That sounds a bit messy.
I guess you want to IMPORT a flash animation in to FC and reexport again after adding some titles.
First you need to convert the Flash file in something that can be edited in FC. Install Perian so you will be able to open the file with QT Player or MPGStreamclip, then convert it to 8b Uncompressed or Prores.
You will be able to add the titles on FC and export the new file with the current codec.
But them you will need some Adobe software (AE, Adobe media Encoder,..) to compress the file again as Flash.
You can also export an H264/Mp4 that will work in Flash Player.
rafael
http://www.nagavideo.com
Paulo Marques
on Dec 21, 2012 at 4:48:14 pm
Hello Rafael,
Many thanks for your reply, i am going to try that because it is very urgent. Maybe you know how to export flash animations to AE? i have done several trys using PNG sequence, swf and mov files with no sucess :(
I wonder what i am doing wrong?
Many thanks
William Carr
on Dec 23, 2012 at 8:43:39 pm
I once accomplished this need with screen capture app-to-ProRes.
