Movie compressing in 4:3 instead of 16:9 in FCP 6
Alexandra Hidalgo
on Dec 19, 2012 at 3:33:17 am
I shot footage with my Cannon HV-30. The sequence settings are Frame Size 1440x1080, aspect ratio HD(1440x1080)(16:9) and pixel aspect ratio HD(1440x1080). The QuickTime Video settings for compressor are HDV1080i60. However, when I compress it into H.264 using 100% of the original, I end up with a 4:3 movie, except for the YouTube version (http://youtu.be/VXAzs9caaZY) which for some very confusing reason is in 16:9. Do you guys have any advice on how to fix this?
Thank you, thank you as always!
Alex
Rafael Amador
Re: Movie compressing in 4:3 instead of 16:9 in FCP 6
on Dec 19, 2012 at 12:19:55 pm
Hi Alexandra.
QT do not understand other than Square pixels.
Export your movie with 1920x1080 Square Pixels.
rafael
http://www.nagavideo.com
Alexandra Hidalgo
on Dec 19, 2012 at 3:31:52 pm
Thanks, Rafael. Do I leave everything else as is and only change the pixel rate in the inspector?
