Error while exporting .MXF from FCP 7
Miguel Ribeiro
on Dec 11, 2012 at 1:28:13 pm
Hi, I am trying to export a timeline from Final Cut to a .MXF file and it is not working.
I select the timeline, go to File>Export>Sony XDCAM, then check the settings and click export.
FCP renders the timeline and then transfer the export to Sony XDCAM Exporter.
When the export is around 20% I get an error saying:
"Please check that the volume to which you are exporting is not locked or full.
Error writing MXF file (while checking expected MPEG-2 picture_coding_type)."
I have tried to export to my RAID and to the desktop, both of them have space and are not locked.
I also managed to export another timeline without any problems.
Can anyone help me with this issue?
Thank you,
Miguel.
Rafael Amador
Re: Error while exporting .MXF from FCP 7
on Dec 11, 2012 at 2:02:55 pm
Hi Miguel,
Nothing wrong.
FCP prevents to export files bigger than 4GBs.
That's the limit for FAT-32 media.
Chop your movie so the FMX don't reach that size.
I think that if you keep the sequence below 14 minutes will go OK.
rafael
http://www.nagavideo.com
Brown Maty
on Jan 22, 2013 at 2:25:52 am
Hello, Miguel.
The MPEG-2 MXF file from Sony XDCAM is too big, I guess.
You need to crop the videos. Or you can transcode the file to Apple ProRes with a smaller file for directly importing to FCP 7 for editing.
Signature´╝Ü Are you Canon EOS C300 users? If so, do you want to get the MXF recordings ...
