Clips fall offline even after reconnect and save
Rosie Walunas
on Dec 11, 2012 at 1:13:01 am
Working with an editor. He says the problem is that the clips fall offline, drive securely connected and all, and even after a manual reconnect and save, it continues to happen. How can this be? What are some solutions?
- Clips may be merged - Video + separately recorded audio (not yet clear which clip, but likely all of the them)
- May be have been synced clips with PluralEyes
- The clips are on a Raid drive system
- No other clips that I know of are going offline
Advice / solutions ASAP would be greatly appreciated.
Thanks.
Sascha Engel
Re: Clips fall offline even after reconnect and save
on Jan 3, 2013 at 3:36:17 pm
If you really saved it the right way, re-connected the clips the right way, and all is fine with your HardDisk and you also checked that the Scratch Disk is set to the Disk in Question, then it might be something inside FC.
Try once to Trash all Preference Files and Plist files and see if it's gone.
Greetings,
Sascha
